Creating a User Role with Active Directory Authentication
Configuring user roles using AD authentication provides broad range of directory-based identity-related services.
To create a User Role with AD authentication:
- Create a new UTP for a particular role, refer Creating a User Traffic Profile.
- Create a role, refer Creating a User Role.
Create a new Proxy AD server and apply the UTP. Refer Creating Proxy AAA Servers.NOTENon-proxy Auth servers are not supported.
Perform an authentication test to ensure that the user gets assigned the correct Role. Refer Testing AAA Servers.NOTEIn step 4 of the authentication test, for the Service Protocol option, choose Active Directory and proceed.
Create a web authentication portal WLAN configuration and assign the Non-proxy AD server to it. Refer
Creating a WLAN Configuration.
- Choose .
Configure the following for
Authentication & Accounting Server:
Web Authentication Portal: choose the option from the drop-down.
Authentication Server: select the Use the Controller Proxy check box and choose the authentication service from the drop-down.
