Configuring Registration Rule Priorities
The controller applies registration rules in the same order as they appear in the AP Registration Rules table (highest to lowest priority).
If you want a particular registration rule to have higher priority, you must move it up the table. Once an AP matches a registration rule, the controller assigns the AP to the zone specified in the rule and stops processing the remaining rules.
Follow these steps to configure the registration rule priorities.
- Go to System > AP Settings > AP Registration.
- Select the rule from the list and click.
- Up—To give a rule higher priority, move it up the table
- Down—To give a rule lower priority, move it down the table
- Click Update Priorities to save your changes.
