Supported SSIDs in ZoneFlex Release 9.6
ZoneFlex release 9.6 supports a specific set of SSID syntaxes, which may be different from the syntaxes supported in other releases.
Table 62 Supported SSID syntaxes in ZoneFlex 9.6
Web Interface Length Between two and 32 characters
Supported Characters All printable ASCII characters from space (32) to ~(126)
Exceptions The space character (32) cannot be the first or last character in the SSID. Otherwise, the following error message appears:
can only contain between 1 and 32 characters, including characters from ! (char 33) to ~ (char 126).
CLI Length Between two and 32 characters
Supported Characters All printable ASCII characters from space (32) to ~ (126)
Exceptions The space character (32) can be placed anywhere in the SSID (including the beginning or end) provided that it enclosed in a double quotation mark (for example, “Ruckus SSID”).
