Supported SSIDs in Releases 9.8, 9.7, and 9.6
ZoneFlex release 9.8, 9.7, and 9.6 support a specific set of SSID syntaxes, which may be different from the syntaxes supported in other releases.
Table 63 Supported SSID syntaxes in ZoneFlex AP 9.8, 9.7, and 9.6
Web Interface Length Between one and 32 characters
Supported Characters All printable ASCII characters from space (32) to ~(126)
CLI Length Between one and 32 characters
Supported Characters All printable ASCII characters from space (32) to ~ (126)
Exceptions The space character (32) can be placed anywhere in the SSID (including the beginning or end) provided that it enclosed in a double quotation mark (for example, "Ruckus SSID").
If the space character is not enclosed in a double quotation mark, the space character and any characters after that will be ignored. For example, if you run the command "set ssid wlan0 ruckus-ap 123", the controller CLI will run the command as "set ssid wlan0 ruckus-ap 123".
