Licensing needs to be created on a per SZ Controller Cluster basis.
To create the DHCP License assignment:
Go to
Select the
DP DHCP/NAT License Assignment tab.
From the
DHCP License area, click
Create.
The
DHCP License form appears.
- License Usage: Lists the details of license consumption and availability.
- Primary Data Plane: Select the primary data plane from the drop-down. To remove the Data Plane from the DHCP license assignment, select
Clear.
- Secondary Data Plane: Select the secondary data plane from the drop-down. To remove the Data Plane from the DHCP license assignment, select
Clear.
- License Count: Enter the number of license. Range: 1 through 101.
- IP Leases: Lists the number of IPs assigned.
- Description: Enter a short description about the license assignment.
Click
OK.
You have created the DHCP license assignment.
To edit or remove the license assignment on the data plane, select the assignment from the list and click
Configure or
Delete respectively.
