Available System Logs for SZ100
The controller generates logs for all the applications that are running on the server.
| Application | Description |
| API | Stands for application program interface (API), this provides an interface for customers to configure and monitor the system |
| AUT | Manages the sessions in the controller's TTG module |
| CaptivePortal | Performs portal redirect for clients and manages the walled garden and blacklist |
| Cassandra | The controller's database server that stores most of the run-time information and statistical data |
| CNR | An application that obtains TTG configuration updates and applies the settings to related modules |
| Configurer | Performs configuration synchronization and cluster operations (for example, join, remove, upgrade, backup, and restore) |
| Diagnostics | An interface that customers can use to upload Ruckus scripts for performing troubleshooting or applying software patches |
| ElasticSearch | Scalable real-time search engine used in the controller |
| Memcached | The controller's memory cache that stores client authentication information for fast authentication or roaming |
| MemProxy | Replicates MemCached entries to other cluster nodes |
| Mosquitto | A lightweight method used to carry out messaging between LBS and APs |
| NC | The Node Controller, which monitors all of the controller's TTG processes |
| Northbound | Performs UE authentication and handles approval or denial of UEs to AP |
| RadiusProxy | Sets the RADIUS dispatch rules and synchronizes configuration to each cluster node |
| SMF | An application that monitors the health of TTG processes |
| SNMP | Provides a framework for the monitoring devices on a network. The SNMP manager is the system used to control and monitor the activities of network hosts using SNMP. |
| SubscriberManagement | A process for maintaining local user credentials for WISPr authentication |
| SubscriberPortal | Internal portal page for WISPr (hotspot) |
| System | Collects and sends log information from all processes |
| Web | Runs the controller’s management web server |
