When an application is unrecognized and generically (or incorrectly) categorized, the controller will be unable to monitor its traffic, unless you configure an explicit application identification policy based on IP address/mask, port and protocol.
To configure a user-defined application:
Go to
Select the
User Defined tab.
Click
Create.
The
Create User Defined Application page appears.
Figure 88
Creating a User Defined Application
Configure the following:
- Name: Type a name for the application. This is the name that will identify this application on the dashboard.
- Type: Select Default or Port Mapping Only (destination port).
- Destination IP: Type the destination IP address of the application.
- Netmask: Type the netmask of the destination IP address.
- Destination Port: Type the destination port for the application.
- Protocol: Select the protocol used by the application. Options include TCP and UDP.
- Click
OK.
You have created the user defined application.
You can also edit, clone and delete the application policy by selecting the options
Configure,
Clone and
Delete respectively, from the
User Defined tab.
