Viewing Statistics for SoftGRE Tunnels
The web interface displays the table and its corresponding graph chart. The two representations are synchronized and controlled by the search criteria. For performance reasons, the total counters per DP or per AP for each bin may be pre-calculated.
To view the SoftGRE Tunnel Statistics:
- From the left pane, select Report > Ruckus AP Tunnel Stats. The Ruckus GRE tab appears by default.
- Select SoftGRE. Update the parameters as explained in the table below.
- Click:
- Load Data— To view the report in the workspace.
- Export CSV—To open or save the report in CSV file format.
| Field | Description | Your Action |
| Time Period | Indicate the time period for which you want to view the report. | Move the slider to set the duration. |
| Zone Name | Specifies the zone for which you want to view the report. | Select the required zone. |
| Gateway Address | Specifies the gateway address | Enter the gateway address. |
| AP MAC or IP Address | Indicates the MAC of the Access Point or IP Address. | Enter the AP MAC or IP address. |
The table below contains the report based on the statistics for SoftGRE. Each entry contains the 15 minutes cumulative data.
| Attribute | Type | Description |
| Time | Long | Bin ID, which is stamped at a 15 minute interval. For example, 10:00, 10:15. |
| TXBytes | Long | Indicates the number of bytes sent. |
| RXBytes | Long | Indicates the number of bytes received. |
| TXPkts | Long | Indicates the number of packets sent. |
| RXPkts | Long | Indicates the number of packets received. |
| RX Dropped Packets | Long | Indicates the number of packets dropped. |
| TX Dropped Packets | Long | Indicates the number of packets dropped. |
| TX Error Packets | Long | Indicates the number of packets with a header error. |
| RX Error Packets | Long | Indicates the number of packets with a header error. |
