Creating WLAN Templates
To create a WLAN template:
- From the application select, System > Templates > WLAN Templates.
- Click Create, the Create WLAN Template form appears.
- Enter a Template Name.
- Enter a Description.
- Select the Template Firmware.
- Choose the AP IP Mode.
- Select AP SoftGRE Tunnel to enable all WLANs defined in this template to tunnel traffic to SoftGRE through the AP.
- Click OK.
You can select a WLAN and edit, clone or delete its template by selecting the options Configure,
Clone or
Delete respectively.
