Creating Bonjour Gateway Policies
A Bonjour Gateway policy must be created for an AP zone before the policy can be deployed to an AP or group of APs.
To create a Bonjour Gateway policy:
  1. Go to Services & Profiles > Bonjour.
  2. Select the Gateway tab, and then select the zone for which you want to create the policy.
  3. Click Create.
    The Create Bonjour Policy page appears.
    Figure 98  Creating a Bonjour Gateway Policy
  4. Configure the following:
    1. Name: Type a name for the policy.
    2. Description: Type a description for the policy.
    3. Rules: Create the policy rule by configuring the following
      1. Click Create. The Create Bonjour Policy Rule page appears.
      2. Configure the following options:
        • Bridge Service: Select the Bonjour service from the list.
        • From VLAN: Select the VLAN from which the Bonjour service will be advertised.
        • To VLAN: Select the VLAN to which the service should be made available.
        • Notes: Add optional notes for this rule.
      3. Click OK.
        You have created a Bonjour policy rule.
    4. Click OK.
You have created a Bonjour policy with a rule.
You can also edit, clone and delete the policy by selecting the options Configure, Clone and Delete respectively, from the Gateway tab.
