Extracting a WLAN Template
You can extract only WLAN-related configuration of an AP to a WLAN template.
Follow these steps to extract a WLAN template:
  1. From the Wireless LANs page, locate the zone from where you want to extract the WLAN template.
  2. Click More and select Extract WLAN Template, the Extract WLAN Template form appears.
  3. In WLAN Template Name, enter a name for the Template.
  4. Click OK, a message appears stating that the WLAN template was extracted successfully.
  5. Click OK.
    The extracted WLAN template can be viewed under System > Templates > WLAN Templates.
