Creating a WLAN Schedule Profile
Follow these steps to create a WLAN schedule profile.
- From the Wireless LANs page, select the WLAN for you want to create a WLAN Schedule profile.
- Click Configure, the Edit WLAN Config page appears.
- Scroll down to the Advanced Options section.
- In the Service Schedule field, select Specific.
- Click Create, the Create Time Schedules Table form appears.
- In General Options, enter the Schedule Name and Schedule Description.
- To set a WLAN schedule:
- To enable or disable the WLAN for an entire day, click the day of the week under the Time column.
- To enable or disable the WLAN for specific hour of a specific day, click the squares in the table. A single square represents 30 minutes (two-15 minute blocks).
Blue-colored cells indicate the hours when the WLAN is enabled. Clear (or white) cells indicate the hours when the WLAN is disabled.
- Click Create, the page refreshes, and then the schedule you created appears in the drop-down list.
