Configuring NAT Pool Setting
To configure NAT pool settings
  1. Go to Services & Profiles > DHCP & NAT > NAT Profiles (DP).
  2. Select the NAT profile from the list and click the Pools tab.
  3. Click Create, the Create Pool Configuration page appears.
  4. Configure the following:
    • General Options
      • Pool Name: Type a name for the NAT pool settings that you want to create.
      • Description: Type a description for the pool settings that you want to create.
    • Policy Options
      • Private VLAN Range: Type the VLAN range and click Add. Range: 1 through 4095. For example: 1 or 1-2.
      • Private QinQ VLAN Range: Type SVLAN range, CVLAN range and click Add. Range: 2 through 4095. For example: 2 or 2-3.
    • Translation Options
      • Port Range: Type the port range. Range: 10000 through 65534. For example: 10000-20000.
      • Public Address Range: Type the public address range.
        Note: This public address must not be duplicated with the other public address in the same subnet, which includes applied NAT Profile and vSZ-D's Access and Core Interface Address.
  5. Click OK. You have created a NAT pool setting.
