Blocking a Wireless Client
When a user associates a wireless client device with an AP that the controller is managing, the client device is recorded and tracked. If, for any reason, you need to block a client device from accessing the network, you can do so from the web interface.
A few reasons why you might consider blocking a wireless client device include:
- Network abuse
- Violation of acceptable use policy
- Theft
- Security compromise
Follow these steps to block a wireless client from accessing the SmartZone network.
- On the menu, click .
- From the list wireless clients, locate the client that you want to block. If you have a large number of wireless clients and you know the MAC address of the client, enter the MAC address in the search box, and then press <Enter> to search for the client.
- When you have located the client, select it, and then click the Block button above the table.
You have completed blocking a wireless client.
