Configuring the Control Plane
Control Plane configuration includes defining the physical interface, user defined interface and static routes.
To configure a control plane:
- Go to System > Cluster > Control Planes.
- Select the control plane from the list and click Configure. The Edit Control Plane Network Settings form appears.
- Configure the settings as explained in the table below.
- Click OK.
You must configure the
Control interface,
IPv4 Cluster interface, andManagement interface to be on three different subnets. Failure to do so may result in loss of access to the web interface or failure of system functions and services.
| Field | Description | Your Action |
| Physical Interfaces | ||
| IPv4-Control Interface | Indicates the management and IP control settings. | Select the
IP Mode:
| IPv4-Cluster Interface | Indicates the IPv4 cluster interface settings | Select the
IP Mode:
| IPv4-Management Interface | Indicates the IPv4 management interface settings | Select the
IP Mode:
| IPv6-Control Interface | Indicates the IPv6 control interface settings | Select the
IP Mode:
| IPv6-Management Interface | Indicates the IPv6 management interface settings | Select the
IP Mode:
| IPv4 Default Gateway & DNS | Indicates the IPv4 gateway that you want to use - Control, Cluster, and Management.
NOTE When
Access & Core Separation is enabled, the
Default Gateway field is hidden.
| IPv6 Default Gateway & DNS | Indicates the IPv6 gateway that you want to use - Control, Cluster, and Management.
NOTE When
| User Defined Interfaces
NOTE The control plane and the UDI must be on different subnets. If the control plane and UDI are on the same subnet, and assigned the same IP address, APs will be unable to communicate with the control plane. If the control plane and UDI are on the same subnet and assigned different IP addresses, hotspot clients will not be redirected to the logon URL for user authentication.
| Name | Indicates the name of the interface. | Enter a name. |
| Physical Interfaces | Indicates the physical interface. | Select Control Interface. |
| Service | Indicates the service. | Select Hotspot, the hotspot must uses the control interface as its physical interface. |
| IP Address | Indicates the IP address that you want to assign to this interface. | Enter the IP address. |
| Subnet Mask | Indicates the subnet mask for the IP address. | Enter the subnet mask. |
| Gateway | Indicates the IP address of the gateway router. | Enter the gateway IP address. |
| VLAN | Indicates the VLAN ID that you want to assign to this interface. | Enter the VLAN ID. |
| Add | Adds the interface settings. | Click Add. |
| Static Routes | ||
| Network Address | Indicates the destination IP address of this route. | Enter the IP address. |
| Subnet Mask | Indicates a subnet mask for the IP address. | Enter the subnet mask. |
| Gateway | Indicates the IP address of the gateway router. | Enter the IP address of the gateway router. |
| Interface | Indicates the physical interface to use for this route. | Select the interface. |
| Metric | Represents the number of routers between the network and the destination. | Enter the number of routers. |
| Add | Adds the static route settings. | Click Add. |
You can also delete or restart a control plane. To do so, select the control plane from the list and click
Delete or
Restart respectively.
