Configuring DHCP Global Settings
- Go to Services & Profiles > DHCP & NAT > DHCP Profiles (DP).
- Click Create, the Create DHCP Profile page appears.
Configure the following:
- Profile Name: Type a name for the DHCP profile you want to create. AP supports 32 bytes.
- Description: Type a description of the settings you want to create.
- Domain Name: Type the domain name address.
- Primary DNS Server: Type the primary domain name server address.
- Secondary DNS Server: Type the secondary domain name server address.
- Lease Time: Type the duration in Hours, Minutes and Seconds. Range: 1 through 86400 seconds.
- DHCP Option43 Space: Click
Create, the Create DHCP Option43 Space form appears. Configure the following:
- Space Name: Type a name for Option43 space.
- Description: Type a description for Option43 space.
- Under
Option43 Sub Option, click
Create and configure the following:
- Sub Option Name: Type a sub option name.
- Type: Select the required option from the drop-down.
- Code: Enter a code. Range: 1 through 254.
- Click OK, you have created Option43 Sub Option.
- Click OK, you have created Option43 Space.
- Hosts: Click
Create, the Create Host Configuration form appears. Configure the following:
General Options
Host: Type a name for the host settings that you want to create.
Description: Type a description for the host settings that you want to create.
Policy Options
Mac Address: Type the MAC address of the DHCP host.
Assigning Options
Broadcast Address: Type the broadcast IP address.
Fixed Address: Type the fixed IP address of the host.
Gateway: Type the gateway IP address.
DNS Server: Type the IP address of the DNS server.
Domain Name: Type the domain name.
Host Name: Type the host name.
- Click OK, you have created DHCP Host configuration.
General Options
- Click OK. You have created DHCP Profile settings.
