Configuring NAT Global Settings
To create a NAT global setting:
  1. Go to Services & Profiles > DHCP & NAT > NAT Profiles (DP).
  2. Click Create, the Create NAT Profile page appears.
  3. Configure the following:
    • Profile Name: Type a name for the NAT profile that you want to create. AP supports 32 bytes.
    • Description: Type a description for the profile that you want to create.
    • Subnet: Type the IP address.
    • Prefix: Type a prefix value. Maximum range: 31.
    • Public VLAN: Type the VLAN range. Range: 2 through 4095.
    • Gateway: Type the gateway IP address.
  4. Click OK. You have created a NAT Profile.
