Implementing an Application Control Policy
Deploying an application control policy involves configuring a User Traffic Profile (UTP) with the policy, and then applying that profile to a WLAN.
To implement an Application Control Policy:
  1. Go to Services and Profiles > Access Control > User Traffic.
  2. Click Create. The Create User Traffic Profile form appears.
  3. Enter a Name, and optionally a Description for the UTP.
  4. In the Application Recognition and Control section, select an Application Policy from the drop-down list. Alternatively, click Create to create a new policy.
  5. Click OK to save the User Traffic Profile.
  6. Go to Wireless LANs.
  7. Locate the WLAN for which you want to apply the application policy, and select it from the list.
  8. Click Configure. The Edit WLAN [WLAN Name] form appears.
  9. Expand the Advanced Options section, and select a User Traffic Profile you created from the drop-down list. Alternatively, click Create to create a new UTP.
  10. Click OK to save your WLAN changes.
    Figure 85  Create a User Traffic Profile (UTP)
    Figure 86  Select an Application Policy to apply to this UTP
    Figure 87  Apply the UTP to a WLAN
