Provisioning and Swapping Access Points
The controller supports the provisioning and swapping of access points.
As an administrator you can:
  • Upload a file containing list of AP and the pre-provisioned configuration data for each AP. The controller processes the file and provides details on regarding the import results (including a list of failed APs and failure reasons).
  • Modify or delete pre-provisioning data if AP does not connect to the controller
  • Monitor the status and stage of the pre-provisioned APs
  • Manually lock or unlock APs
  • Upload a file containing list of AP pairs for swapping. The controller processes the file and provide the detailed import result (including a list of failed APs and failure reasons).
  • Manually enter the AP swap pair
  • Delete the swap configuration if AP fails to contact the controller
  • Monitor the status and stage of the swapping AP pairs
  • Manually swap the APs
