Creating Zone Templates
To create a zone template:
- From the application select, System > Templates > Zone Templates.
- Click Create, the Create Zone Template form appears.
- Enter the template details as explained in the table below.
- Click OK.
| Field | Description | Your Action |
| General Options | ||
| Zone Name | Indicates a name for the Zone. | Enter a name. |
| Description | Indicates a short description. | Enter a brief description |
| AP Firmware | Indicates the firmware to which it applies. | Select the firmware. |
| Country Code | Indicates the country code to ensure that this zone uses authorized radio channels. | Select the country code. |
| Location | Indicates generic location. | Enter the location. |
| Location Additional Information | Indicates detailed location. | Enter additional location information. |
| GPS Coordinates | Indicates the geographical location. | Enter the following coordinates in meters or floor:
| AP Admin Logon | Indicates the admin logon credentials. For the Default Zone, the SZ cluster name is used as the default logon ID and password. | Enter the Logon ID and Password. |
| Time Zone | Indicates the time zone that applies. | Select the option:
| AP IP Mode | Indicates the IP version that applies. | Select the option:
| Radio Options | ||
| Channel Range | Indicates that you want to override the 2.4GHz channel range that has been configured for the zone. | Select Select Channel Range (2.4G) check boxes for the channels on which you want the 2.4GHz radios to operate. Channel options include channels 1 to 11. By default, all channels are selected. |
| DFS Channels | Allows ZoneFlex APs to use DFS channels. | Select the check box. |
| Channel Range (5G) Indoor | Indicates for what channels want the 5GHz radios to operate. | Select the check boxes. |
| Channel Range (5G) Outdoor | Indicates for what channels want the 5GHz radios to operate. | Select the check boxes. |
| Radio Options b/g/n (2.4 GHz) | Indicates the radio option 2.4 GHz configurations. | Select the following options:
| Radio Options a/n/ac (5 GHz) | Indicates the radio option 5 GHz configurations. | Select the following options:
| AP GRE Tunnel Options | ||
| Tunnel Type | Indicates the support for NAT. |
Choose the required tunnel type:
| Syslog Options | ||
| Enable external syslog server for Aps | Indicates if an external syslog server is enabled. | Select the check box and update the following details:
| AP SNMP Options | ||
| Enable AP SNMP | Indicates if the AP SNMP option is enabled. | Select the check box. |
| SNMPv2 Agent | Indicates SNMPv2 Agent is applied. |
| SNMPv3 Agent | Indicates SNMPv3 Agent is applied. |
| Advanced Options | ||
| Channel Mode | Indicates if location-based service is enabled. | Select the check box and choose the option. |
| Auto Channel Selection | Indicates auto-channel settings. | Select the required check boxes and choose the option. |
| Background Scan | Runs a background scan. | Select the respective check boxes and enter the duration in seconds. |
| Smart Monitor | Indicates AP interval check and retry threshold settings. | Select the check box and enter the duration and threshold. |
| AP Management VLAN | Indicates the AP management VLAN settings. | Choose the option. If you select
VLAN ID, enter the VLAN ID that you want to assign (valid range is from 1 to 4094). To keep the same management VLAN ID that has been configured on the AP, click
Keep AP's settings.
ATTENTION For standalone APs, set the AP ethernet port to trunk before changing the AP Management VLAN settings.
| Rogue AP Detection | Indicates rogue AP settings. |
| DoS Protection | Indicates settings for blocking a client. | Select the check box and enter the:
| Client Load Balancing | Balances the number of clients across APs. | Select the check box and enter the threshold. |
| Band Balancing | Balances the bandwidth of the clients. | Select the check box and enter the percentage. |
| Location Based Service | To disable the LBS service for this AP group, clear the Enable LBS service check box. To use a different LBS server for this AP group, select the Enable LBS service check box, and then select the LBS server that you want to use from the drop-down list. | Select the check box and choose the options. |
| Client Admission Control | Indicates the load thresholds on the AP at which it will stop accepting new clients.
NOTE Client admission cannot be enabled when client load balancing or band balancing is enabled.
Select the
Enable check box 2.4 GHz Radio or 5GHz Radio and update the following details:
| AP Reboot Timeout | Indicates AP reboot settings. | Choose the required option for:
You can select a zone from the list and edit, clone or delete its template by selecting the options
Configure,
Clone or
Delete respectively.
