Classifying Rogue Policy
You can create rogue classification policy with rules at the zone-level. This helps in automatic classification behavior when a specific-rogue detection criteria are met.
To create a rogue classification policy:
You can also edit or delete a Rogue classification policy. To do so, select the rogue classification from the list and click
Configure or
Delete as required.
To prioritize the classification rule, select the rule from the list and click
UP or
Down to position the rule.
