Configuring SCI Settings
SmartCell Insight uses data from the controller to analyse performance and generate reports about the WiFi network. Configuring the SCI settings in the controller enables data transfer from the controller to the SCI server using the MQTT protocol.
Follow these steps to configure the SCI server settings:
- Go to System > General Settings > SCI.
- Select the Enable SCI check-box to configure the SCI server settings.
- Click Create, the Create SCI Profile form appears.
- Enter the following details:
- Name—Profile name.
- Server Host—IP address to the SCI host server.
- Server Port—Port number over which the SCI server and controller can communicate and transfer data.
- User—Name for the user.
- Password—password for the respective user.
- System ID—ID of the SCI system that should be accessed.
- Click OK.
You can also edit or delete an SCI profile. To do so, select the SCI profile from the list and click
Configure or
Delete as required.
