Configuring Global Filters
The Global filter setting allows you to set your preferred system filter.
Global filters allow the administrator to define a system scope or system context that applies to all pages of the system as they navigate to different menus. For example, if your system includes 5 zones, but you want to view Zone1 and Zone2 only, you can create and apply such a filter. As you navigate throughout the system, the view will be restricted to show only the data, objects, and profiles contained within Zones 1 and 2.
To set the global filter:
- From the
Header bar, click
Filter setting
. The below figure appears.
Figure 3 Global Filter Form
- Select or clear the required system filters and click
- Save—To save the filter settings with the default group.
- Save As—To save the filter settings as a new group. The below figure appears. Enter a new name for the group and click
OK.
Figure 4 New Name Form
You can delete the filter setting. To do so, click the Filter
setting button. The Global Filter form appears, click
Delete.
