You can add RADIUS servers that you want to use for authorizing and authenticating administrators.
Go to
Select the
AAA tab.
Click
Create.
The
Create Administrator RADIUS Server page appears.
Figure 124
Creating an Administrator RADIUS Server
Configure the following:
- Name: Type a name for the RADIUS server.
- Type: Select the type of RADIUS server that you are using. Options include:
- RADIUS: Click this option to use a Remote Authentication Dial-In User Service (RADIUS) server on the network for authenticating controller administrators.
- TACACS+: Click this option to use a Terminal Access Controller Access-Control System Plus (TACACS+) server on the network for authentication controller administrators.
- Realm: Type the realm (or realms) to which the RADIUS server belongs. If the RADIUS server belongs to multiple realms, use a comma (,) to separate the realm names.
- Backup RADIUS: Select the Enable Secondary Server to back up the RADIUS server configuration.
- Primary Server: Type the IP address, port, shared secret for the primary server that needs to be backed up.
- Secondary Server: Type the IP address, port, shared secret for the secondary server to which the back must be done.
- Failover Policy at NAS:'
- Request Timeout: Type the timeout period (in seconds) after which an expected RADIUS response message is considered to have failed.
- Max Number of Retries: Type the number of failed connection attempts after which the controller will fail over to the backup RADIUS server.
- Reconnect Primary: Type the number of minutes after which the controller will attempt to reconnect to the primary RADIUS server after failover to the backup server.
- IP Address: Type the IP address of the RADIUS server.
- Port: Type the UDP port that the RADIUS server is using. The default port is 1812.
- Shared Secret: Type the shared secret.
- Confirm Secret: Retype the same secret in.
- Click
OK.
You have completed adding a RADIUS server for authenticating administrators.
You can also edit, clone and delete the server by selecting the options
Configure,
Clone and
Delete respectively, from the Administrator tab.
