Assigning Certificates to Services
You can map certificates to services
To specify the certificate that each secure service will use:
  1. From the application select, System > Certificates > Service Certs.
  2. Select the certificate that you want to use for each of the following services:
    • Management Web—Used by Web UI and Public API traffic.
    • AP Portal—Used by Web Auth WLAN and Guest Access WLAN control traffic.
    • Hotspot (WISPr)—Used by WISPr WLAN control (Northbound Interface, Captive Portal, and Internal Subscriber Portal) traffic.
    • Communicator—Used by AP control traffic.
  3. To view the public key, click View Public Key, the Certificate Public Key form appears with the public key.
  4. Click OK.
