Generating Reports
To generate a report:
- From the left pane, select Report > Report Generation. FigureĀ 123 appears.
- Select the required report from the list and click Generate. The Report Generated form appears.
- Click OK, the report will be generated and listed in the Report Results area.
- Select the required format from the Result Links column and click Open.
