There are two methods you can use to back up the controller configuration either using the web interface or CLI (Command Line Interface).
Follow these steps to back up the controller configuration from the
CLI.
Log on to the controller
CLI as a system administrator.
Run the
enable command to enable privileged mode on the
CLI.
ruckus> enable
Password: ********
ruckus#
Run the
backup config command to start backing up and transferring the node configuration to an FTP server.
ruckus# backup config <ftp-username> <ftp-password> <ftp-server-address> <ftp-server-port>
Do you want to backup configuration (yes/no)? yes
Backup Configuration process starts
Backup Configuration process has been scheduled to run. You can check backup version using 'show backup-config'
Run the
show backup-config command to verify that the backup file has been created.
You have completed backing up the controller node to an external FTP server.
