Limiting the AP count for a Partner Domain or a System Zone
Only super admin of the system domain is privileged to limit the number of APs in a partner domain or a system zone.
 To limit the number of AP count for a partner domain or a system zone:
	 - Log on to the controller web interface using super admin credentials of the system domain.
		   Follow the procedure to limit the number of APs in the partner domain or a zone in system domain:
		  - Go to System > AP Settings > AP Number Allocation.
- For Enable AP Number Allocation, select the Enabled check box and click OK. The Settings bar appears.
- From the left pane, in the system tree hierarchy, select the partner-managed Domain or Zone for which you want to set the AP number limit.
- On the right pane, select Share Mode or enter the Number Limit.
- Click OK. You have set the AP number limit for the selected Domain or Zone.
