Configuring System Time
The controller uses an external network time protocol (NTP) server to synchronize the times across cluster nodes and managed access points.
To edit the system time:
  1. Go to System > General Settings > Time.
  2. Enter the NTP Server address that you want to use. The default NTP server address is ntp.ruckuswireless.com.
  3. Click Sync Server to enable an AP to join the controller and automatically synchronize its time every day.
  4. Select the System Time Zone, from the drop-down that you want the controller to use. The default time zone is (GMT +0:00) UTC.
  5. Click OK.
