Restoring Configuration to Multiple Nodes in a Cluster
If the cluster itself is not healthy anymore or if multiple nodes need to replaced, you must you must factory reset all remaining nodes to ensure that configuration restore to the cluster will be successful.
Follow the steps to restore the configuration to multiple nodes in a cluster.
  1. Prepare the new controller nodes and factory reset all of the existing nodes in the cluster.
  2. Complete the setup procedure for one of the controller nodes.
    For instructions, see the SmartCell Gateway 200 Getting Started Guide for this release.
  3. After you complete the setup of one node, log on to the web interface of that node as a system administrator.
  4. Go to Administration > Backup and Restore.
  5. In the Configuration tab, click Upload.
  6. Locate the configuration backup file that you want to restore.
  7. Click Upload.
    After the configuration file is uploaded successfully, it appears in the Configuration section.
  8. Restore the configuration backup to the node either using the web interface or the CLI.
  9. To use the web interface:
    1. Go to Administration > Backup and Restore page.
    2. In the Configuration tab, locate the configuration backup file that you want to restore.
    3. Click Restore.
    4. Follow the prompts (if any) to complete the restore process.
  10. To use the CLI:
    1. Log on to the CLI of the node as a system administrator.
    2. Run the restore config command.
      ruckus# restore config
      This action will REBOOT the system. Do you want to only restore this SCG node (yes/no)? yes
      idx version date
      1 1.1.1.0.93 2013-02-01 03:09:27 GMT
      2 1.1.1.0.93 2013-02-03 07:21:24 GMT
      Please choose a backup version to restore (ex: 1, 2, ...): 2
    3. When the configuration restore process on this node is complete, set up the next node and configure it to join the existing cluster.
You have completed restoring configuration backup to multiple nodes in a cluster.
