Extracting a Zone Template
You can extract the current configuration of a zone and save it as a zone template.
Follow these steps to extract the configuration of a zone to a zone
template:
- From the Access Points page, locate the zone from where you want to extract the WLAN template.
- Click More and select Extract Zone Template, the Extract Zone Template dialog box appears.
- In Zone Template Name, enter a name for the Template.
- Click OK, a message appears stating that the zone template was extracted successfully.
- Click OK. You have completed extracting a zone template.
The extracted Zone template can be viewed under System > Templates > Zone Templates.
