Diagnostics
- Applying Scripts
New AP models and firmware updates are supported without the need to upgrade the controller image by using AP patch files and diagnostic scripts. - Applying AP CLI Scripts
New AP models and firmware updates are supported without the need to upgrade the controller image by using AP CLI scripts. - Viewing and Downloading Logs
The controller generates logs for all the applications that are running on the server. - Viewing DHCP Relay Settings
You must be aware of the DHCP relay settings on the controller to monitor the health of the controller. - GGSN
- RADIUS
