Enabling Flexi VPN
You can enable Flexi-VPN and limit the network resources that a UE can access. Flexi-VPN allows an administrator to customize the network topology, and is thereby able to control the network resources accessible to the end-user. This feature is only supported on vSZ-E and vSZ-H, and is enabled by purchasing the Flexi-VPN license.
  1. Go to Services & Profiles > Tunnels and Ports.
  2. Select the Forwarding Rule(DP) tab.
    The page with Flexi-VPN and L3 Roaming settings appears.
    Figure 109  Enabling Flexi-VPN
    The Flexi-VPN option is available only if the Access-VLAN ID is configured in manual mode, and when VLAN Pooling, Dynamic VLAN and Core Network VLAN options, and Tunnel NAT are disabled.
    You can only apply 1024 WLAN IDs to a Flexi-VPN profile.
    Flexi-VPN supports IPv4 addressing formats and Ruckus GRE tunnel protocol. It does not support IPv6 addressing formats.
  3. Select a virtual data plane for which you want to enable the Flexi-VPN feature, and then select the Enable Flexi-VPN check-box.
  4. Click OK.
You have successfully enabled the Flexi-VPN feature on the selected vDP.
