Viewing Cluster Configuration
Cluster redundancy is supported only on SZ300 and vSZ-H.
Follow these steps to view the cluster configuration:
- Go to System > Cluster. The Cluster page appears.
- Select the cluster, scroll down and click the Configuration tab. You can view the cluster details listed in the following table.
| Field | Description |
| Cluster Configuration | |
IP Support |
Displays IP support version |
| Cluster Redundancy | |
| Status | Displays the cluster redundancy status. |
| Cluster Redundant Role | Displays the cluster redundancy role. |
| Active Cluster | Displays name and control IPs of active cluster |
| Standby Cluster | Displays name, management IPs, and control IPs of standby cluster |
| Schedule Configuration Sync |
