| Community |
Indicates that applications which send SNMP Get-Requests to the controller
(to retrieve information) will need to send this string along with the request
before they will be allowed access. |
Enter a name. |
| Authentication |
Indicates the authentication method. |
Choose the required option:
- None—Use no authentication.
- SHA—Secure Hash Algorithm, message hash function with 160-bit
output.
- Enter the Auth Pass Phrase.
- Choose the Privacy option.
- None: Use no privacy method.
- DES: Data Encryption Standard, data block cipher.
- AES: Advanced Encryption Standard, data block cipher.
- Enter a Privacy Phrase, 8 through 32 characters.
- MD5—Message-Digest algorithm 5, message hash function with 128-bit
output.
| Privilege |
Indicates the privileges granted to this community. |
Select the required privileges:
- Read—Privilege only to read.
- Write—Privilege only to read and write.
- Notification—Privilege to:
- Trap—Choose this option to send SNMP trap notification.
- Inform—Choose this option to send SNMP notification.
- Enter the Target IP address.
- Enter the Target Port number.
- Click Add.
