Applying a Zone Template
You can apply an AP zone configuration template to a zone.
Follow these steps to apply a zone template:
- From the Access Points page, locate the zone where you want to apply the zone template.
- Click More and select Apply Zone Template, the Import Zone Template dialog box appears.
- From the Select a Zone template drop-down, select the template.
- Click OK, a confirmation message appears asking to apply the zone template to the AP zone.
- Click Yes. The zone template was applied successfully.
You have completed applying zone template to the AP zone.
