Monitoring APs Using the Map View
Use the Map view on the Access Points page to monitor APs in relation to your venue's floorplan.
- Go to Access Points.
- In View Mode, click the Map button. The map view is displayed with your placed APs.
Hover over an AP to view the following AP-specific details:
- AP Name: The name of the AP, if configured. If not, the default AP name is "RuckusAP."
- IP Address: The current IPv4 or IPv6 address assigned to the AP.
- Channel: Displays the channel (2.4 GHz / 5 GHz) in use, along with the channel width in parentheses.
- Clients: The number of currently connected wireless clients.
- Traffic: The total traffic volume over the last 1 hour.
- Latency: The average time delay between AP and connected clients.
- Airtime Utilization: Percent of airtime utilized, by radio.
- Connection Failure: Percent of client connection attempt failures.
Figure 32 Hover over an AP to view details
- To view more specific details on the AP, click the See this AP in AP page link.
- To view the RF signal strength, select the Show Signal Coverage check box and choose the required RF frequency. For example, 2.4 GHz or 5 GHz. The heat map is displayed with a color-gradient legend. High signal strength appears in red. The color changes as the signal strength reduces.
Parent topic: Working with Maps
