Viewing a Summary of Wireless Clients
View a summary of wireless clients that are currently associated with all of your managed access points.
Go to Clients > Wireless Clients. The Wireless Clients page appears and displays a table that lists all clients that are currently associated with your managed access points.
To view only wireless clients that belong to a particular zone, click the zone name in the zone tree. The table refreshes and displays only the clients that belong to the zone you selected.
The following table lists the wireless client details.
Not all of the columns listed below are displayed by default. To display column that are currently hidden, click the gear icon in the upper-right corner of the table, and then select the check boxes for the columns that you want to display.
You can view the clients listed in the table in two view modes - No TTG (without TTG) and TTG (with TTG).
Click the icon to export all the data into a CSV file.
Table 22 Wireless client details
Column Name Description
Hostname Displays the hostname of the wireless client
OS Type Displays the operating system that the wireless client is using
IP Address Displays the IP address assigned to the wireless client
MAC Address Displays the MAC address of the wireless client
WLAN Displays the name of the WLAN with which the client is associated
AP Name Displays the name assigned to the access point
AP MAC Displays the MAC address of the AP
Traffic (Session) Displays the total traffic (in KB/MB/GB/TB) for this client in this session
Traffic (Uplink) Displays the total uplink traffic (in KB/MB/GB/TB) for this client in this session
Traffic (Downlink) Displays the total downlink traffic (in KB/MB/GB/TB) for this client in this session
RSSI Displays the Received Signal Strength Indicator (RSSI), which indicates how well a wireless client can receive a signal from an AP. The RSSI value is shown in decibels (dB) and displayed as either the real-time value or the average value over the past 90 seconds.
SNR Displays the Signal-to-Noise Ratio (SNR), which indicates the signal strength relative to background noise. The SNR value is shown in decibels (dB) and displayed as either the real-time value or the average value over the past 90 seconds.
Radio Type Displays the type of wireless radio that the client supports. Possible values include 11b, 11g, 11g/n, 11a, 11a/g/n, and 11ac.
VLAN Displays the VLAN ID assigned to the wireless client
Channel Displays the wireless channel (and channel width) that the wireless client is using
User Name Displays the name of the user logged on to the wireless client
Connected Since Displays the time from which the AP is connected to the wireless client
# of Events Displays the number of client events
Data Rate (Up) Displays the rate at which data is transmitted from the wireless client to the AP
Data Rate (Down) Displays the rate at which data is transmitted from the AP to the wireless client
Auth Method Displays the authentication method used by the AP to authenticate the wireless client
Auth Status Indicates whether the wireless client is authorized or unauthorized to access the WLAN service
Encryption Displays the encryption method used by the AP
Control Plane Displays the name of SmartZone node to which the AP's control plane is connected
Packets to Displays the downlink packet count for this session
Packets from Displays the uplink packet count for this session
Packets dropped Displays the downlink packet count for this client that have been dropped
The client is automatically unauthenticated by the WLAN if the client is connected for 48 hours in the Standard+Open/ Standard+MAC Auth authentication method, and for 12 hours in the Standard+802.1x EAP authentication method.
