Rehoming Managed APs
Rehoming is the process of returning the APs that have failed over to the standby cluster back to their original cluster (once it becomes available). Rehoming must be done manually. APs that have failed over will continue to be managed by the failover cluster until you rehome them.
To rehome managed APs, you must enable cluster redundancy so that the APs will continue to be managed by the failover cluster until you restore them to the original cluster (rehome) manually. See
Enabling Cluster Redundancy.
Rehoming APs must be done on a per-cluster basis. Follow these steps to rehome managed APs to the original cluster.
- From the Access Points page, select the System to activate rehome operation.
- Click More and select Rehome Primary Cluster . A confirmation dialog box appears.
- Click Yes, you have set active cluster to rehome.
