Creating a WLAN Domain for an MSP
A Managed Services Provider (MSP) manages and assumes a defined set of responsibility. You can create an MSP managed domain, to manage all their settings within that domain. You can also limit the number of APs per zone. Refer, Limiting the Number of APs in a Domain or Zone.
To create a WLAN Domain for an MSP:
  1. From the Wireless LANs Page, select System from the tree hierarchy.
  2. Click the Create button, the Create Group form appears.
  3. Configure the following details:
    1. Enter a Name for the domain.
    2. Enter a Description about the domain.
    3. By default, the Type selected is Domain.
    4. The Parent Group displays the group to which this domain will be tagged.
    5. In Managed by Partner, select the Enable check box.
  4. Click OK. You have created a new WLAN domain. In the left pane, the new MSP domain appears.
