General Ports
General ports are user-specified ports that can have any combination of up to 20 VLAN IDs assigned.
General ports function similarly to Trunk ports, except that where Trunk ports pass all VLAN traffic, General ports pass only the VLAN traffic that is defined by the user.
To configure an AP Ethernet port as a General port, select General Port and enter multiple
valid VLAN IDs separated by commas or a range separated by a hyphen.
You must also
include the Untag VLAN ID in the Members field when defining the VLANs that a General port
will pass. For example, if you enter 1 as the Untag VLAN ID and want the port to pass
traffic on VLANs 200 and 300, you would enter: 1,200,300.
