Creating an AP Domain
To create an AP domain:
- From the System tree hierarchy, select the location where you want to create the domain.
- Click the Create
button, the Create Group
form appears. - Configure the following details:
- Enter a Name for the domain.
- Enter a Description about the domain.
- By default, the Type selected is Domain.
- The Parent Group displays the group to which this domain will be tagged.
- If you want to create a domain to manage MSP-related settings within that domain, in the Managed by Partner field, select the Enable check box.
- Click OK.
You can also edit, clone and delete an AP Domain by selecting the options Configure
, Clone
or Delete
respectively, from the Access
Points page.
