Overview of Access Point Configuration
Once you have created registration rules and the AP zones to which joining access points can be assigned automatically, access points will be able to join or register with the controller automatically.
Whenever a new AP connects to the controller and before it gets approval, the AP registration is moved to "Pending" state determining there is communication between the AP and controller. Every time an unapproved AP attempts to register, a "AP reject" event is generated and can be exported to syslog server if there is one configured.
AP reject event is generated only once since subsequent events are suppressed to reduce resource usage.
After an access point registers successfully with the controller, you can update its configuration by following the steps described in this section.
