Introduction
The information in this section only applies to the SCG-200.
This section describes how to back up cluster and configuration data and replace a controller node.
The following are required to perform the procedures described in this guide.
- A remote FTP server with at least 50GB of free disk space. You must create an FTP account (user name and password) before starting these procedures.
- If you are restoring to a multi node cluster environment, all backup files must be taken around the same time. If the backup files are out-of-sync, the restore process may be unsuccessful.
