Supported SSIDs in Releases 9.8, 9.7, and 9.6
ZoneFlex release 9.8, 9.7, and 9.6 support a specific set of SSID syntaxes, which may be different from the syntaxes supported in other releases.
| Web Interface | Length | Between one and 32 characters |
| Supported Characters | All printable ASCII characters from space (32) to ~(126) | |
| CLI | Length | Between one and 32 characters |
| Supported Characters | All printable ASCII characters from space (32) to ~ (126) | |
| Exceptions | The space character (32) can be placed anywhere in the SSID (including the beginning or end) provided that it enclosed in a double quotation mark (for example, "Ruckus SSID"). If the space character is not enclosed in a double quotation mark, the space character and any characters after that will be ignored. For example, if you run the command "set ssid wlan0 ruckus-ap 123", the controller CLI will run the command as "set ssid wlan0 ruckus-ap 123". |
