Printing the Guest Pass
After you generate the guest pass, you can print the guest pass information, which contains the guest user information and instructions on how to connect to the hotspot, and give it to the guest user.
If your browser is blocking pop-ups, make you temporarily disable the pop-up blocker so you can view and print the guest pass.
Follow these steps to print a guest pass.
  1. From the generated guest passes list, select the guest passes that you want to print.
  2. In Guest Instruction HTML Template, select a printout template to use.
    The default printout template (default.html) is selected by default. If you created custom printout templates (see Creating a Guest Pass Template), they will appear in the drop-down menu.
  3. Click Print Selected. A new browser page appears, which displays the guest pass and available printing options.
  4. Configure your printer settings, and then print the guest passes.
You have completed printing the guest passes.
Figure 55  What a guest pass printout looks like
