Available System Logs for SZ100
The controller generates logs for all the applications that are running on the server.
Application | Description |
API | Stands for application program interface (API), this provides an interface for customers to configure and monitor the system |
AUT | Manages the sessions in the controller's TTG module |
CaptivePortal | Performs portal redirect for clients and manages the walled garden and blacklist |
Cassandra | The controller's database server that stores most of the run-time information and statistical data |
CNR | An application that obtains TTG configuration updates and applies the settings to related modules |
Configurer | Performs configuration synchronization and cluster operations (for example, join, remove, upgrade, backup, and restore) |
Diagnostics | An interface that customers can use to upload Ruckus scripts for performing troubleshooting or applying software patches |
ElasticSearch | Scalable real-time search engine used in the controller |
Memcached | The controller's memory cache that stores client authentication information for fast authentication or roaming |
MemProxy | Replicates MemCached entries to other cluster nodes |
Mosquitto | A lightweight method used to carry out messaging between LBS and APs |
NC | The Node Controller, which monitors all of the controller's TTG processes |
Northbound | Performs UE authentication and handles approval or denial of UEs to AP |
RadiusProxy | Sets the RADIUS dispatch rules and synchronizes configuration to each cluster node |
SMF | An application that monitors the health of TTG processes |
SNMP | Provides a framework for the monitoring devices on a network. The SNMP manager is the system used to control and monitor the activities of network hosts using SNMP. |
SubscriberManagement | A process for maintaining local user credentials for WISPr authentication |
SubscriberPortal | Internal portal page for WISPr (hotspot) |
System | Collects and sends log information from all processes |
Web | Runs the controller’s management web server |
