Configuring Registration Rule Priorities
The controller applies registration rules in the same order as they appear in the AP Registration Rules table (highest to lowest priority).
If you want a particular registration rule to have higher priority, you must move it up the table. Once an AP matches a registration rule, the controller assigns the AP to the zone specified in the rule and stops processing the remaining rules.
Follow these steps to configure the registration rule priorities.
  1. Go to System > AP Settings > AP Registration.
  2. Select the rule from the list and click.
    • Up—To give a rule higher priority, move it up the table
    • Down—To give a rule lower priority, move it down the table
  3. Click Update Priorities to save your changes.
