Synchronizing Controller with the License Server
By default, the controller automatically synchronizes its license data with the selected license server every 24 hours. If you made changes to the controller licenses (for example, you purchased additional licenses) and you want the controller to download the updated license data immediately, you can trigger a manual synchronization.
  1. Log on to the controller web interface, and then go to Administration > Licenses.
  2. Select the Installed Licenses tab.
  3. Click Sync Now.
    When the sync process is complete, the message Sync license with the license server successful appears. If the previously saved license data are different the latest license data on the server, the information in the Installed Licenses section refreshes to reflect the latest data.
You have completed manually synchronizing the controller with the license server.
