Importing Installed Licenses
If the controller is disconnected from the Internet or is otherwise unable to communicate with the Ruckus SmartLicense system (due to firewall policies, etc.), you can manually import a license entitlement file into the controller.
The option to import a license file manually into the controller is only available if the controller is using the cloud license server.
  1. Obtain the license file. You can do this by logging on to your Ruckus Support account, going to the license management page, and then downloading the license file (the license file is in .bin format).
  2. Log on to the controller web interface, and then go to Administration > Licenses.
  3. Select the Installed Licenses tab.
  4. Select the node for which you are uploading the license file and click Upload.
    The Upload License page appears where you must provide the following information:
    • Select Controller: Select the node for which you are uploading the license file.
    • Select License File: Click Browse, locate the license file (.bin file) that you downloaded from your Ruckus Support account, and then select it.
The page refreshes, and the information displayed changes to reflect the updated information imported from the SmartLicense platform.
